TwoTonYoda's avatar
TwoTonYoda
Follower
Apr 29, 2018
Xr500 Nighthawk A can not connect B should I update to Version V2.2.1.10. C. Update process
Xr500 Nighthawk new out of box.  Windows 10 64 bit updated to current on hardwired unit. Current firmware V2.0.0.28.
Returned X10 and bought this today. Currently at the screen through initial set up asking if I want to update to firmware V2.2.1.10
A. No connection
B. Should I update in this fashion or some other way such as extracting and uploading zip.
Error  when connecting states. This site can’t be reached.  Netflix unexpectedly closed the connection. ERR_connection_closed. Same error on a laptop, a Mac, a phone an iPad.  Also same in chrome, Safari or IE.   please help
  • You have to complete the setup in order to initiate the internet connection. It should allow you to update to the latest firmware in setup. Then when you exit the setup wizard you'll have internet.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Has your issue been fixed? A user on the Netduma forum provided the following information for you:
      I was also facing this error recently. And While searching about it found a solution which you can also use. It worked for me.
      Go to Command Prompt by pressing windows key and X and select Command Prompt.
      Now, just paste these commands one by one and after every command hit enter.
      Commands: ipconfig /release
      ipconfig /all
      ipconfig /flushDNS
      ipconfig /renew
      netsh int ip set DNS
      netsh winsock reset
      Lastly, just reset your PC or the device and see if it makes any changes.
    A. No connection
    Well you can try this method. This is more a common problem for everyone.
    ipconfig /all
    ipconfig /flushDNS
    ipconfig /renew
    netsh winsock reset
