Hookset's avatar
Hookset
XR500 not able to use ethernet ports
Wifi works great. Ethernet when plugged into my PC shows "Network cable unplugged" in adapter settings and has not internet. The ethernet1 light is not on. This is also after i have tried disabling and enabling the ethernet adapter. I have a Spectrum modem and 300download 10upload on wifi. Any help here??
  • FURRYe38's avatar
    Try different port, lan cable or different PC or other device. Cat 6 is recommended.
    • Hookset's avatar
      Hookset
      Firmware is V2.3.2.134
      using the cat 5e cable that was included with the router. cat 6 is going from modem to router.
      only numbers on the ISP modem are S/N: . CM MAC:. MTA MAC:
      The modem is brand new, just got spectrum internet last week and the xr500 this week.
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        Can you try the ethernet cable from your PC to the XR in a couple of different LAN ports on the XR? That way we'll know if it's just an issue with the LAN port on the XR or not.
