ficlet's avatar
ficlet
Tutor
May 18, 2023
XR500 not displaying traffic prioritization
Hey there!
I'm running a XR500 and am having trouble getting my ping down/stable while gaming with Sea of Thieves. My friends report pings in the 50-60 range while I consistently am between 90-150. I can't seem to use the GeoFilter or Ping Heatmap features as SoT uses Unreal Engine and is not in the dropdown list. I've tried looking into traffic prioritization but it never loads in DumaOS (see image below).
I've set my pc as a gaming console in the device manager and resynced the cloud. I also tried release/renewing my network connection as well as doing a hard reset on the router itself.
Any recommendations? Thanks in advance!
  • FURRYe38's avatar
    What browser are you using?
    Try MS-Edge or Firefox?
    What FW version is loaded?
    • ficlet's avatar
      ficlet
      Tutor
      I'm using Chrome but can try Edge or Firefox. The FW is V2.3.2.134.
