nf_
Mar 02, 2020Aspirant
XR500 Performance over time
I have a Nighthawk XR500 (firmware V2.3.2.56) that seems to have performance issues that worsen over time.
When the router has been running for a while, modules stop loading in the web-interface with errors like "The operation is taking longer than expected. Please briefly wait before using this R-App."
Waiting, however, does not help and the module never loads. Not even after a router re-boot.
Rebooting the router can temporarily resolve some issues but not all.
I have experienced VOIP disconnecting after 5-10 seconds (Team Speak and Discord).
Rubber-banding and package loss is also, but more briefly, helped by a re-boot.
I have also reset to firmware which helps some modules load in the web-interface that did not load before, but then others fail in stead. And over time more and more fail to load.
After my latest reset I get a "Device not found" error in QoS and the module for "Traffic Prioritization" (add remove devices) never loads.
Is this how the router is expected to perform? Is there a more permanent fix than re-boot / reset?
Is it just my device that’s broken?
- Netduma-FraserNetDuma PartnerWhat web browser are you using to access the interface? Also are you accessing via HTTPS or HTTP? In System Information in the R-App panel options change the number of retries from 3 to 5. In WAN Settings toggle SIP ALG and if you're still having an issue switch NAT to Open. Also then clear your browser cache/cookies, once you've done this reboot the router, have the issues improved?
- nf_Aspirant
Thank you for your reply.
I use regular http on FireFox and Chrome, on PC and Mac. The issues atre the same on all platforms.
Updating settings as you instructed helped loading web-interface, but in QoS I still get a "Device not found" and "Traffic Prioritization" never loads.
I will leave these settings on for a few days and see if it has helped in the long run too.
Thanks again, and I'll report my findings.
- Netduma-FraserNetDuma PartnerIt sounds like a device being changed or deleted has caused both those QoS issues. Has any device been altered or removed? If so adding it back/changing the name to the original should resolve that, otherwise I think a factory reset would be the only way - not using the backup file if you have one.
