PINGIU987's avatar
PINGIU987
xr500 problemi in game
dopo una partita che gioco va bene ma dalla seconda in poi mi crasha in game  dopo continua a darmelo e sena risultati se si può fare qualcosa
    • PINGIU987's avatar
      PINGIU987
      after a game I play okay on then crashes me into play after keep giving it to me and senain if you can do anything
  • FURRYe38's avatar
    Who is your Internet Service Provider and is there a modem or separate internet service unit device that your ISP installed that gives you internet to the XR router? We need the manufacture and model# of this modem unit that your ISP may have installed.
    This is not the NetGear XR router.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        What game are you playing? Are you using the Geo-Filter? Are the disconnects just from the game or the internet also?
