Agentwhite's avatar
Apr 14, 2021
XR500 R apps stop working 24 hours after a router reboot
I'm running firmware v2.3.2.66 and my R apps all throw the same error message: Error: This R-App is not loaded yet, please try again in a minute.
If I reboot the router, they will load and work for about 24 hours before failing to load and throwing the error message again. This problem didn't exist in the past but I can't say for sure if it started after a firware upgrade. I can say that the current firmware version was not what came from the factory so I know I've done at least 1 upgrade since purchasing.
I do see that I can upgrade to v2.3.2.114 firmware but I'm hesitant because I can't find full release notes between my version and this latest version and feel like I may end up introducing new bugs.
Wondering if there are known issues with v2.3.2.66 or any other suggestions to solve this problem.
  • michaelkenward's avatar
    michaelkenward
    What feeds the router? A modem of some sort? If so, the make and model might be useful information.
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
    Nighthawk Pro Gaming Routers - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done this already. I can't tell from your message.
  • On the System Information page in the Rapp panel options change the retries to 5 then reboot the router from the interface and see if it lasts longer then
