LukeEyre01's avatar
Mar 02, 2021
XR500 Reboot
Hi,
I have recently upgraded my internet package to a 600mbps package, ever since I have upgraded my netgear router constantly reboots. All the lights go orange and it then reboots back up to white. When logged into Duma OS my cpu is sitting mostly sitting around 80+. I have an ISP router in modem mode and have checked that is not rebooting or anything. I have tried moving plug etc I have done a reset, I have downgraded to the last firmware. Anyone else experiencing these problems?
  • Unplug the router fully from the power for 10 minutes to start with, then plug it in, does it continue to reboot? If so then remove the WAN/internet cable from it, does it still occur?
    • LukeEyre01's avatar
      LukeEyre01
      Tutor
      Hi,
      I have tried leaving it unplugged for 10 mins, still no change. it doesn’t reboot when there is no internet cable plugged in.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Could you take the ISP router out of modem mode please, then reconnect it to the XR - does it continue to reboot then?
