TayJBuiz's avatar
TayJBuiz
XR500 Rebooting Itself After Attempts at Streaming and Downloading
As the title says, for some reason my new Netgear router is crashing non-stop whenever I attempt to use my WiFi to stream or download games for my console. I've had this device since last month and I switched Internet providers at the same time, so I assumed it was my new modem. Nope. After attempting to watch my smart tv, the router crashed and entered a reboot state, and my modem was doing perfectly fine. I don't know why it's doing this, and any help would be great.
  • Could you please go to Settings -> Setup -> LAN setup and change the minimum DHCP pool address to 192.168.1.50.
    Then add IP address reservations for each device on the network, make sure you give each device a different address between 192.168.1.2 and 192.168.1.49.
    After that check if the problem still occurs.
    • TayJBuiz's avatar
      TayJBuiz
      There's no "minimum". I have "Starting IP address" and "Ending IP address", then I also have IP Subnet Mask. I'm completely new to all of this.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Enter the starting IP as .50, then process with the reservations. Don't change anything else, you can leave subnet mask as it is. If you're unsure don't hesitate to ask!
