joshkay13
Nov 21, 2018Aspirant
XR500 VOIP registration problem
I have an xr500 and an allwork 9204 VOIP phone from work that I can use to work from home. When I attempt to set up my phone it fails the registration process. This seems to be a problem with the router as I am able to hook the phone up directly to my modem and it works fine. I set up a static IP for the phone and put it in a DMZ. I also disabled SIP ALG but it still does the same thing. The phone did detect that it needed an update and applied that so it seems to have partial connectivity through the router.
- Netduma_JackNetDuma Partner
That does sound like a NAT problem. Have you set NAT filtering mode to open in WAN setup?
If that doesn't fix it, I'd recommend getting in touch with NETGEAR's offcial support. They should be able to help get this sorted for you
Here's the support link in case you need it: https://www.netgear.com/support/contact.aspx
- joshkay13Aspirant
Thanks but Ive had the router long enought that I dont have support on it anymore. I do have NAT filtering set to open.
