BmoreBateman
Nov 08, 2019Guide
XR500 Wifi Slows to a crawl
Hey everyone,
I have been banging my head against the wall the last few days. I have been having a issue with my XR500 that I have had for awhile now. I cannot seem to keep my wifi speeds stable. Temp fixes are to disconnect my phone from the wifi and reconnect it to start getting it to work for 20ish min.
2 nights ago I went ahead and reset my router completely and set it up from scratch. I did a channel scan to make sure I am not over lapping anyone (I am now the only one on the specific channel). Yesterday I was getting about 500-600Mbps and thought it was solved but I awoke this morning to it going back down to under a 1Mbps. I have toggled QoS off and on, no devices are in Geo-Filter, No DMZ host and UPNP is turned on.
Please help!
edit: forgot to add
I have Gigibit Fios without a router so I dont have to worry about their device having wifi turned on. all wired devices do not seem to have a issue.
Firmware version XR500 V2.3.2.56
Great News! I rolled back the firmware, replaced the power cord because it randomly went into a boot loop on .32, Moved the router in a Upstairs closet on the other side of the floor... everything has held stable. I even updated the firmware to the current version Friday night. Everything has held strong in that time. I'm saying I was either getting really bad interference where it was at or the power cable was failing and wasn't providing enough power.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Set 20/40Mhz Coexistence to 40Mhz only.
Is Smart connect enabled or disabled?
Hey thanks for the reply. I have done a channel scan and verified that channel 8 was empty on 2.4Ghz so I'm using that, 136 on 5Ghz. I live in a townhome complex so i have alot of people near by. I can see 40 devices when I did my Channel scan.
Beamforming was on by default and i toggled the 20/40 Coexistence with no success.
Smart connect is on currently.
- Netduma-FraserNetDuma PartnerJust to confirm your disabled QoS completely from the Anti-Bufferbloat 3 line menu and still suffering from slow speeds? What speeds do you get when you're using a wired connection? Disable smart connect and connect to 5GHz manually, are the speeds still slower?
