Ziptie's avatar
Ziptie
XR500 Wifi speeds very slow
I've tried everything this forum mentioned
Turn off QoS, turn of data sharing, wifi setup with Dumas, Set MAC address to previous router and nothing worked
Qos is set 300 up and 300 down 100%
My ISP speed should be 300mb up and down
I have tried on 2 different computers for speed testing - macbook pro and gaming pc - both wireless and wired (plug into XR500)
Wireless i get 100-130 down 300up - on both computers
Wired (plug into XR500) I get 310 down 300up
So im sure its Wifi setting / config / hardware issue
I need help fixing this issue
Please and thank you
  • Turn off Smart Connect and connect to the 5GHz, what do you get with that?
    Also download a WiFi analyser and change it to the least congested channel. Weird though that the down on wireless is the only thing affected
    • Ziptie's avatar
      Ziptie
      Smart connect in Router (Dumasos) setting?
      • Ziptie's avatar
        Ziptie
        Smart Connect is off ... and wifi analyzer .. what exactly am I looing for ?
  • FURRYe38's avatar
    What Is your ISP suppeed UP and down that you pay for?
    What devices are you using to speed test?
    Wireless speeds on most wifi devices max out at around 400-500Mb on 5Ghz AC.
    • Ziptie's avatar
      Ziptie
      300mb down 300mb up
      and I get 120down 290-300 up on wifi 5G
      300 down 300 up if I connect via ethernet to XR500
      i've tried it all that I could ... please help
      • Netduma_Jack's avatar
        Netduma_Jack
        NetDuma Partner
        That's so weird. It's just your download speed that's slow over WiFi? Everything else is hitting expected speeds i.e. LAN, upload over WiFi?
        Is there anything using the connection at the same time that could be slowing this down?
        In >QoS >Anti-Bufferbloat, have you set your max speeds to 300mbps in the Antu-Bufferbloat settings?
