TimboSlice1967's avatar
Dec 18, 2022
XR700 Firmware
So "upgraded" my XR500 after suffering serious lag issues while playing COD, to an XR700. Updated to the "latest" beta firmware (1.0.1.34_DUMAOS3.0_6) nearly two years ago. Still suffering with horrendous lag when other devices in the house are streaming video. No update on firmware in two years, still on a beta version. XR500 has been updated multiple times, as have R1 and R2 and XR1000. Seriously peaved with the lack of support on this router that cost a bloody fortune and was advertised to solve all my gaming issues. Can anyone advise me on a better router with better customer support?
  • So "upgraded" my XR500 after suffering serious lag issues while playing COD, to an XR700.  Updated to the "latest" beta firmware (1.0.1.34_DUMAOS3.0_6) nearly two years ago.  Still suffering with horrendous lag when other devices in the house are streaming video.  No update on firmware in two years, still on a beta version.  XR500 has been updated multiple times, as have R1 and R2 and XR1000.  Seriously peaved with the lack of support on this router that cost a bloody fortune and was advertised to solve all my gaming issues.  Can anyone advise me on a better router with better customer support?
    • Kitsap's avatar
      Kitsap
      Master
      You are in the wrong community for Pro Gaming Routers.  You need to post in the community specifically set aside for the Pro Gaming Router products.
      Here is the link:  https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
    • FURRYe38's avatar
      Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
      What gaming device are you playing on?
      Are you playing over wireless or wired connection? Wired is preferred.
      Any of the XR series routers should work. May need some help in some configurations is all...
      • TimboSlice1967's avatar
        TimboSlice1967
        Router is connected to a modem made for Virgin Media, it's an Arris TG3492LG-VBM , PS5 connected direct via Cat7 cable.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Can you provide a screenshot of your QoS page please? What is the model of the modem/router the XR is connected to? Are ALL devices connected to the XR?
        TimboSlice1967
        We're with Virgin Media, on there fastest fibre package.  Modem is an Arris TG3492LG-VBM made specifically for Virgin Media.
        All devices are connected to the router, most directly by Cat 7 cables, there are a couple of gigabit switches due to the amount of devices we have (mostly stuff in standby etc) and WiFi runs everything else such as mobile phones, Ring doorbell, Hive hub for central heating.
        PS5 is connected direct to Router via Cat 7 cable.
        Dumaos app for iphone will not connect since last update,  Loaded latest Dumaos beta 3 and factory reset, still a bag of crap!
