cloidhamer's avatar
cloidhamer
XR700 spamming all network ports
I have an issue where all the ports on my network show traffic and the router and any device on my network is unreachable. A reset of the router fixes the issue. When this happened I unplugged each device to see if it was something on the network. It was not, and since power cycling my router fixed the issue it must be a problem with the XR700. Also I haven;t changed anything on my network since installing the XR700 and have never seen this issue before. Any help would be appreciated.
BTW NetDUMA blows. I was excited for some really cool features, but it has way under delivered and is slow and laggy.
  • What hardware do you have upstream from the router? If you've got an ISP router you might need to change some settings there to get the XR700 working properly. For example, changing the XR700's IP from 192.168.1.1 to 192.168.x.1 where x is any number you like
    • cloidhamer's avatar
      cloidhamer
      I use my own cable modem, so there are no ip issues. It happens randomly and since I have to reset the router there is no way to check the logs.
  • FURRYe38's avatar
    What devices and or switches do you have connected?
    Do you have any static IP address asigned devices?
    I didn't experience this with mine. I have many LAN devices connected along with LAN switches.
    What FW version are you on?
    Try setting the DHCP IP address pool size to 192.168.1.100 to .200.
      cloidhamer
      LIke I said this network has been operating flawlessly for 5 years until I added the XR700. I will try a wireshark next time it happens, which should be within the week or sooner, to see if I can gain any data to post here.
      It's unfortunate that I paid this much for a router and OS that is clearly not worth it.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        I have asked Christian_R to add you to the beta group for XR700 firmware. There are a few firmware versions there that are not publicly available, they may help to resolve the issue you're having.
