tasonthego1
Jul 22, 2025Follower
It keeps telling me there is no internet and won’t let me connect with the anywhere access
I have this same issue. It keeps telling me there is no internet and won’t let me connect with the anywhere access in the Orbi app. I’ve done a reboot, turned the web protection off in the Netgear VP...
Jul 22, 2025Guru - Experienced User
What Orbi model system do you have?
What mobile platform do you have Orbi app installed on?
Can you access the system at 192.168.1.1 using a PC and web browser?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Can you try a factory reset on the system and setup from scratch using a PC and web browser and walk thru the routers setup wizard. Then after that completes, try accessing the system using Orbi app?
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
or Orbi Systems Manual Factory Reset Process | NETGEAR Communities
Then:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
