Daniel-UK
May 16, 2019Apprentice
Network map keeps randomly changing on iPhone app
When I look at the Network Map in the iPhone app, I keep getting always different network topology and differen colours for the devices (green, magenta, orange) every time I look at it!
Strangely e...
SW_
May 17, 2019Prodigy
Daniel-UK, to improve 2.4Ghz speed, please disable 2.4Ghz co-existence (untick the box). If that doesn't help, try reducing the transmit power for 2.4Ghz from 100% to 50% or even 25% to nudge the iPhone toward 5Ghz. After you made the change, reboot Orbi and give it ~15mins for the dust to settle.
Daniel-UK
May 17, 2019Apprentice
I have already done exactly what you suggested. Unfortunately with no luck, even with 25% power the 2.4Ghz is preferred :-(
Now I have a perfectly working network but speed is limited because the band steering doesn't seem to work properly :-(
I read quite a few threads on this issue and also BEAMFORMING not helping/working..
As an alternative, is there a way to make the splitted SSIDs working? Should I try to get back to an old firmware?
- SW_May 17, 2019Prodigy
Daniel-UK, can you try to forget the WiFi setup on the iPhone, wait for 2mins and then reconnect?
I also have RBR50 with 2 Satellites with couple iPhones. My average speedtest for the iPhone is ~200Mbps-250Mbps. I letf my transmit power at 100% for both 2.4Ghz and 5Ghz. Here is a picture of my wireless settings.
Can you download NetSpot to check if your 2.4Ghz channel is shared with another device or neighbor?
Can you turn off all Satellites and try Speedtest using this link, http://speedtest.googlefiber.net with above settings? (Please reboot Orbi and do at least 3 runs)
There could be some stale settings that are still stuck in Orbi. We could clean those out starting with the Orbi itself if the above speedtest result is still poor. We can do that next. If we're gone through all the experiments and the problem still exist, you could go back to v210 and stay there. You can disable auto-firmware update using this link.
The iPhone tends to remember/reuse old WiFi settings and may not switch to a different band, especially when the same SSID is (re)used. The Orbi band steering seems to work as expected. Please check out this thread. If your other devices do not suffer from speed issue, it's most likely an issue with iPhone settings.
- Daniel-UKMay 17, 2019Apprentice
I experienced this issue also with my laptop. Not just the iphones. Speedtest gives me full speed when I am on 5Ghz but only ~50MB/s on 2.4Ghz.
I just noticed I have firmware 2.3.1.60 while you still have the 2.3.1.44?
Can you update your firmware and see if it works?
I will also try few reboots and other settings and let you know.
Oh, that picture is from a prior firmware version, but those settings have not changed since day 1. I'm currently on v60 and I did not have slow speed issue. BTW, 50MB/s (Mega Byte per sec) is much faster than 50Mbps (Mega Bit per sec). I don't think Orbi can get 50MB/s on 2.4Ghz or we wouldn't be having this discussion. :smileyhappy:
Assuming your Orbi gets 50Mbps, it implies your device is either not compatible with 40Ghz band, not able to use 40Ghz band, or 2.4Ghz/5Ghz Co-existence is not active on Orbi.
To check this out, try these two tests:
- Toggle "Enable 20/40 MHz Coexistence" (Enable/Apply, Disable/Apply)
- Disable 5Ghz broadcast, verify that client is connected to 2.4Ghz, then run speed test
- Disable 2.4Ghz broadcast, verify that client is connected to 5Ghz, then run speed test
Having disabled the "Enable SSID Broadcast" below for the 5Ghz doesn't turn off the 5Ghz band... even after few reboots and with the other satellites turned off.
i.e. there are still devices connected to the 5Ghz band
How can I turn it off?
Can't see the picture yet, it needs approval.
If devices are connected to 5Ghz when it's not broadcasting, it implies that those devices still remembered/reused their old settings to connect blindly (hidden network) unless Orbi rejects them. To work around this problem, try to change to a new/different SSIDs for 2.4Ghz/5Ghz testing purposes.
So the 5Ghz would be still on and only the SSID is not broadcasted?
If this is the case then I could do the speed test from the device that is on each band. Or am I missing something?
Yes, that's correct. It's akin to hidden 5Ghz network. Yes, just verify the test device is connected to the right band for testing and ignore the rest.
