OfficerUA
Apr 03, 2026Aspirant
Network map
I have a bit similar problem. I have a router with the latest firmware version (V7.2.8.2_5) and a satellite with an old version (V3.2.17). The satellite appears online as a "router" and does not all...
OfficerUA
RBR750 Router (V7.2.8.2_5) + RBS 750 (V7.2.8.2_5) + RBS750 (V3.2.17) Sattelites. Have a problem with RBS750 (V3.2.17).
- FURRYe38Apr 03, 2026Guru - Experienced User
You need to try to apply the v4 version of FW and see if the one RBS can be updated to that first, then try loading v7.
https://www.netgear.com/support/product/rbs750
Down at the bottom look for Prior Versions.
Does the one RBS still connect to the RBR or can't get to it's web page at all?
If you can't get to the one RBS web page, try this:
Orbi Satellite (RBS) Self-Service Web Page Access | NETGEAR Communities
Also there is newer FW available as well for the 750 series:
New - Orbi RBK750/850/860/960 Series Firmware Version 7.2.8.5 Released | NETGEAR Communities
