louisfabbri's avatar
louisfabbri
nighthawk appp
Netgear CAX80 Cable/Modem using nighthawk app. The app is stating "Your Cable Router is offline or not activated", but I am online and things seem to be working correctly. Can anyone help? TIA, Lou F.
  • plemans's avatar
    are you able to log in through the browser?
    I've seen a few reports lately of app issues
  • Hi Lou,
    If you are able to access the internet and your Netgear CAX80 modem is working correctly, but you're still seeing the "Your Cable Router is offline or not activated" message in the Nighthawk app, there are a few things you can try:
    Check for updates: Make sure you have the latest version of the Nighthawk app installed on your device. You can check for updates in your device's app store.
    Restart the app: Close the Nighthawk app and then reopen it. This may help refresh the app and clear any errors.
    Check your device's connection: Make sure your device is connected to the same Wi-Fi network as your Netgear CAX80 modem. If you're not connected to the correct network, the app may not be able to communicate with the modem.
    Reset the modem: If none of the above steps work, you can try resetting your Netgear CAX80 modem to its default settings. Keep in mind that this will erase any custom settings you may have configured.
    If you're still experiencing issues after trying these steps, you may want to contact Netgear support for further assistance. They may be able to provide more specific troubleshooting steps or help you identify if there is a larger issue with the modem or app.
    I hope this helps! Let me know if you have any further questions or concerns.
    • louisfabbri's avatar
      louisfabbri
      Thanks joelthompsons I'll work on it this weekend.
      I have since realized my issue (flaky internet connection) started when I did a CAX80 restart. The restart was needed because I changed the modem's password for security reasons and it did not work. Changing the password is not as simple as it appears. Thanks again. Lou F.
