Crasje
Feb 20, 2026Tutor
Orbi 870 Anywhere access error
Hi, I have an error while trying to turn on the Anywhere access. It was on but since 2 days gives me an error (see attachment). " some error occurred while enabling disabling anywhere access"...
- Feb 20, 2026
Internet search turned up this:
Orbi RBR50 - Cannot Enable Anywhere Access in iOS App | NETGEAR Communities
Feb 20, 2026Guru - Experienced User
What version of the Orbi app do you have installed on your phone or pad?
What brand and model phone or pad are you using?
Does this happen with a different phone or pad?
Remove the app from the phone or pad then reinstall the app?
Can try to submit a bug report thru the app:
How to report a bug on the Orbi App FAQ | NETGEAR Communities
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
What Firmware version is on the Orbi system?
Is IPv6 enabled on the RBR?
Using ISP detected DNS or custom DNS?
Has a power off for 1 minute then back ON with the ISP modem and router and satellite(s) been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
If all else fails, you'll need to factory reset the system and setup from scratch. I would try setting up with a ethernet connected PC and web browser first:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
- CrasjeFeb 20, 2026Tutor
Latest version, 2.51.0.37
Iphone 16 pro, iPad pro (M4)
Both
And rebooted iPhone in between
Also latest vv10.5.20.4_1.3.5
Private IP address disabled
Yes
No, since I am using the router in AP mode. This might be a thing, I just received a new Modem of my provider to enable more than 1GB i-net. But my ISP router is IPv6 enabled.
Same? Since I am using in AP mode. My ISP Modem uses specific DNS's for IPv4 and IPv6.
Does this help?
- FURRYe38Feb 20, 2026Guru - Experienced User
Try the Orbi system in router mode, use the ISP routers DMZ for the RBR in router mode to avoid the double NAT condition here. Then see if using Orbi app works, then see if you can connect Orbi app to the Local connection to the system, then see if you can disable Anywhere Access while in the Local connection mode on the app.
How is the RBR configured for AP mode? Using Dynamic IP configuration or Static configuration?
Possible that Orbi app and AP mode and AA may have a problem or the ISP router maybe interferring with something.
