BretD
Mar 30, 2018Administrator
Orbi App, Easily Setup, Control and Monitor your Orbi Whole Home WiFi
The NETGEAR Orbi app makes it easy to set up and personalize your Orbi WiFi System. With the app, you can install your mesh system in few steps - just connect your mobile device to the router network and the app will walk you through the rest. Once set up, you can use the intuitive dashboard to pause Internet on your connected devices, run a quick Internet speed test, setup smart parental controls and much more.
Download the Orbi App for your Orbi Whole Home WiFi System.
Network Management, just a tap away
- One simple management dashboard - View the status of your network, notifications, and all the features your router offers.
- Pause WiFi for your connected devices - View a list of your connected devices with the ability to pause and resume Internet access.
- Internet Speed Test - Check the broadband speeds from your service provider.
- Setup Smart Parental Controls - Enable Circle® with Disney to easily manage content and time online for every family member.
- And more…
Orbi Pro users go here for the Insight Network Management App:
- Chemo29Guide
You should add this disclaimer:
However, the app will only work intermittently, if ever, because your ORBI will keep dropping the Wifi and internet connection.
- aazVirtuoso
Chemo29wrote:You should add this disclaimer:
This has not been true for me. The Orbi has been more stable than any other router I've had in the past 15 years. I know it's sarcasm, but it's only true for a minority of users on here that the Orbi has been unstable for some unknown reason most likely due to environment.
- AniDuttaApprenticeOrbi app is useless in AP mode. Why can't the app have the functionality to pause internet in AP mode? Even Circle doesn't work on AP mode.
- Paulleyva1977AspirantI have the satellite in my room n my Xbox1x is hooked up to it thru WiFi. Can I or should I just run a Ethernet cord from the satellite to my Xbox?. And can I tell some how if their is a good clean connection between the router n the satellite.??
Yes, you can ethernet connect the xbox to the satellite.
Check Connected Devcies on the routers web page for status of signal of the Satellite connection. You can check the status as well form the satellites web page as well.
- DittimTutor
My Orbi app used to provide stats on data useage. but all of a sudden, the history is gone! the Orbi has been up for 70 days so not sure what happened - was there a change made on the app?
