Barrydet's avatar
Mar 28, 2026
Orbi app problems
I upgraded to the Orbi 700 series.  I followed the app instructions.  During the instructions I renamed the factory issued account name to a personal account name for the system.  Moving on to add the satellites, the app locked up and would not proceed.  I deleted the app and reloaded the app.  Now the app locks up at the  log in page when attempting to log in to link the Orbi devices to the app.  Can anyone offer any guidance??  Thanks
  • CrimpOn's avatar
    CrimpOn
    Do you have a device with a large enough screen to run the Orbi web interface?
    Desktop, laptop, tablet?
    I have found the Orbi 'app' to be a bit tricky when connecting to the router.  Sometimes, it asks for login information, and it is not clear whether the app wants the web administration credentials or the app login credentials.  (It often suggests email addresses that I have not used for YEARS.)  Using the web browser interface avoids that ambiguity.
    • Barrydet's avatar
      Barrydet
      Tutor
      I learned a solution by contacting 24/7 tech support by phone.  The solution is to depress the reset button on the rear of the 870 router for 60 seconds two times.  The LED power indicator lamp will turn from green to orange color.  This action will erase the memory of the 870 device.  The device will return to the factory set SSID.  This will allow the Orbi app or the web browser interface to find the device and link to the device.  Thanks to everyone for the coaching tips.
      • FURRYe38's avatar
        A 15 second press on the reset button and release should have worked as well.
  • I renamed the factory SSID credential to the name and password of the existing Orbi network name as I am upgrading to the 870 equipment.
  • CrimpOn's avatar
    CrimpOn
    "account name" seems ambiguous.  There are three sets of credentials in connection with Orbi WiFi systems:
    • The primary WiFi network credentials, which are printed on the product label.
      The name (SSID) is usually the letters "ORBI" plus two digits.  The password is a couple of random words and some digits.
      Many users rename these credentials to match the WiFi system that is being replaced.
    • The web administration credentials.  The user name is always "admin" (lower case) and cannot be changed.
      The password is initially "password" and the user is badgered into changing it to something "more secure".
    • The Orbi app credentials are usually the email address and password used to log into the Community Forum.
    Which of these credentials were changed during the setup?
  • StephenB's avatar
    Were you able to complete the setup using the web interface?
    If not, then use the router IP address if you know it, otherwise use orblilogin.com
