pgbauer
Apr 15, 2020Initiate
Orbi App Remote Management Not Enabling
Hi, eveytime I go into my Orbi App on my iPhone and go to settings to enable remote management - when I move the slider it then comes up with a error message that states "Something went wrong, sorry about this. Please try again." I have rebooted the orbi gateway, rebooted my phone and tried many times to enable the remote function on my orbi app with the same outcome - help needed to fix this please & thank-you. My system is a Orbi Pro SRR60 Gateway & 1 x Pro Satellite both have the up to date firmware installed. System is running in router mode.
- Christian_RNETGEAR Employee Retired
pgbauer,
Please refer to page 125 of the user manual to set up remote mangement.
http://www.downloads.netgear.com/files/GDC/SRK60/SRK60_UM_EN.pdf
Christian
- pgbauerInitiate
Hi Christian,
Does this mean that the Orbi App on my iPhone will not be able to have remote management set-up on it and that I can only set it up within the router and then access with the IP address's I set up within the router. Thanks for your help with this, very much appriecated.
Hi pgbauer,
After setting up remote management, you can move forward with setting up remote access on the Orbi app. I have linked an article for directions.
https://kb.netgear.com/000058240/How-do-I-enable-or-disable-remote-access-on-my-Orbi-router
Christian
Christian,
I have the identical problem and it only developed in the last couple of months. Previously, my Orbi App connected remotely with no issue. But it is now stopped. I've reinstalled the app, but no luck. When choosing "enable remote management" part of the Orbi App, the error message noted earlier is this thread is all I receive. The app connects just fine when I'm home and on the wi-fi setting. It's only the remote management part of the Orbi App that has stopped working.
