buzzoff's avatar
buzzoff
Luminary
May 09, 2025
Orbi Statistics
Can someone give me a link to understand the statistics report found under Internet Port in the Orbi Management System?
Router:  RBR40 V.2.7.5.6
Satellites: RBS20 (2 of them) V.2.7.5.6
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WAN1000M/Full1610411170263048645534002:12:50
LAN 1Link Down39064000000:00:00
LAN 2Link Down00:00:00
LAN 3Link Down00:00:00
WLAN b/g/n400M29902911900305456195402:12:26
WLAN a/n/ac866M82530544072902:12:18
WLAN Backhaul866M36406829382406597676002:12:18
Trying to understand what Lan 1, 2 & 3 are and why the Links are down.
  • Those are the lan 1-3 ports. Do you have something hardwired into the router on them?
    Right now nothing is connected to them according to the statistics.
  • Plemans, thank you for the quick response.  I think you hit the nail on the head.  I do have ET for my laptop off the RB40 and my tv off the RB20 satellite.  Basically there are 2 ET cables hanging off my RB40 and one off the RB20.
    Appreciate your help!
  • plemans's avatar
