Killer492
Jul 27, 2023Follower
Parental Control and Anywhere Access Broken
So Anywhere Access and Parental Controls have been intermittent for years. Have tried all the “fixes”, but still not working for more than a few days at a time. Lately, I’ve noticed that the Anywhere Access will stop functioning, and when I get home, the Parental Controls have stopped logging activity for the same period of time as the AA was non-functional. All other devices in the home are functioning normally, and I can access the doorbell camera and security system in my Orbi network just fine, but the Orbi App cannot find my router. When I get home, I have to restart the router to force the Parental Controls to begin logging again. Is this happening to anyone else? Can someone please fix the Access issues that have been happening for years?
1 Reply
What Orbi app version are you using?
What mobile platform
What Orbi model do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageHas a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Beta testers should test for a week, then FR.
(Known issues with 970 and FR. More time is needed in stability on the 970. 10 minutes for stablizing.)
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
