buzzoff
May 09, 2025Luminary
RB20 Appears Good but seems to Fail
I have an RB40 and 2 RB20s. We had some internet issues, with the ISP and after all fixed, one of the RB20s shows Backhaul as Good but every time I use something attached to that RB20, that device f...
May 24, 2025Guru - Experienced User
- there's RBS (satellite) and RBR (router). There isn't an RB40/20. Is it the satellite giving you issues or the router?
- If its the satellite, that system is quite old, and you can probably fine people selling old 40/50 series orbi's for really cheap that you could by the system and just use the satellites. Plus then you have a backup router. Or you can get on of the 50 series routers with the wider backhaul and upgrade. My local book of face has them for super cheap.
buzzoff
May 24, 2025Luminary
- RBR 40 and RBS20 (2) - Yes, the RBS20
- If I upgrade to 50 series can I use the current Netgear Config (RBR40)? I use Access Control and have a lot of MAC addresses I would hate to manually input.
- Ok, where do I find your "book of face" page?
- plemansMay 25, 2025Guru - Experienced User
I've never tried a config between 2 different orbis of the same generation. its generally not recommended between different routers. You can always make a backup and give it a try. Worst you're out is some time. In term of the "book of face", just go on your local facebook market place and search for orbi. My area had a ton of them. You'll even find them on things like shopgoodwill for cheap.
- buzzoffMay 26, 2025Luminary
Thanks, plemans! I would hope that Orbi has a way to import the .cfg. I would hate to manually rebuild but may be what needs to be done. You are right that the system is old and actually looking for one with a weatherproof satellite to get down to my driveway entrance. Any recommendations?
- plemansMay 27, 2025Guru - Experienced User
The only orbi outdoor satellite was the RBS50Y. It still sells for quite a bit even on the used site because of its rarity.
