buzzoff
May 09, 2025Luminary
RB20 Appears Good but seems to Fail
I have an RB40 and 2 RB20s. We had some internet issues, with the ISP and after all fixed, one of the RB20s shows Backhaul as Good but every time I use something attached to that RB20, that device f...
May 25, 2025Guru - Experienced User
I've never tried a config between 2 different orbis of the same generation. its generally not recommended between different routers. You can always make a backup and give it a try. Worst you're out is some time. In term of the "book of face", just go on your local facebook market place and search for orbi. My area had a ton of them. You'll even find them on things like shopgoodwill for cheap.
buzzoff
May 26, 2025Luminary
Thanks, plemans! I would hope that Orbi has a way to import the .cfg. I would hate to manually rebuild but may be what needs to be done. You are right that the system is old and actually looking for one with a weatherproof satellite to get down to my driveway entrance. Any recommendations?
- plemansMay 27, 2025Guru - Experienced User
The only orbi outdoor satellite was the RBS50Y. It still sells for quite a bit even on the used site because of its rarity.
