PhilBeard
Mar 15, 2020Aspirant
RBR50 Connection Problem with iPhone
I tried to install the latest firmware update to my RBR50 router through the Orbi App on my iphone. The app tells me that I am not connected to the router even though I am using the wifi network provided by the router. I followed the help suggestions and turned off my two satellites but that didn't help. I tried the "connect remotely" option from the App and was told that the router is not on line. It has to be online beause I still have my wifi network throughout thehouse and internet connction is good. My router is equipped with the BitDefender option; I don't know if that has an impact. So, in summary my wifi network is working well I just can't access my RBR50 to update the firmware.
Hi PhilBeard,
You may need to factory reset the Orbi router by holding down on the reset button for 15+ seconds. You will need to run through the setup assistant again.
Christian
- Christian_RNETGEAR Employee Retired
Hello PhillBeard,
You may try reinstalling the Orbi app. You may also try forgetting the WiFi network on your iPhone and reconnecting to the WiFi network.
Christian
- PhilBeardAspirant
Thanks. I tried both but neither solved the problem.
Hi PhilBeard,
Christian
