if42
May 26, 2025Tutor
unable to access web interface, and orbi app fails to connect too (RBRE960)
hey, I have the Orbi AXE11000 Quad-Band WiFi 6E Router (RBRE960) with two satellites. At the moment I am unable to access the system settings, however I try: Web interface, fails to respond...
if42
Jun 06, 2025Tutor
I gave up and did the hardware reset in the end.
But I am concerned about why it happened, and whether it will happen again.... No one gave me a straight answer as to the cause.
ageinghack
Jun 06, 2025Tutor
if42 wrote:I gave up and did the hardware reset in the end.
That is often required when you make changes to your network.
JJB702 wrote:I have the same problem, RBRE960, moved router and modem to another connection point and this issue began.
You don't say what you mean by that. In particular what is this "another connection point".
When you install a modem and router they have to negotiate a connection depending in the local circumstances. If you move them to a different Internet source, then the hardware has o work out how to make that connection.
Not sure that I understand this bit.
JJB702 wrote:I cannot access router from Orbi app or from a PC, internet works fine
Should there be some more punctuation in there?
- JJB702Jun 06, 2025Aspirant
The connection point was in the same house with the same internet provider, just a different location. That is when the "device not found" issue began. I put the modem and router back into the original connection point in the house and the problem persists. When I get several hours open to connect 6 satellites to the system I will do the factory reset.
Thank goodness I still have internet and the system is working fine, just no access to the router configuration screen from a PC or Orbi app.
- FURRYe38Jun 06, 2025Guru - Experienced User
Hopefully the FR should clear this all up. Something that maybe needed here.
I recommend using this process to do it:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
Works well for me.
Just finished the Factory Reset, all is working well now.
Thanks for all of the help Netgear Community!!!
