staceyw5's avatar
staceyw5
updating firmware
My orbi is running a very old firware (1.4 something) and I want to update it, (I have to do it manually, will not work through app). I downloaded the files on my macbook, and when I go to open it I get an error saying select an .img file, but that is what it is. My macbook states it cannot read th .img file. Any suggestions? (I am trying to install 2.2, as it says I have to do this before 2.3).
  • You don't actually open the .img file. Download the file from the netgear support site, extract it, and then upload it through the web browser. you'll go to advanced--administration--router update. Use the manual installation method
     Keep in mind, you must update to version 2.2.1.212 and then you can update to the most recent version. Here's the support site with the firmwares and the manual that walks you through installation.
    https://www.netgear.com/support/product/RBR50.aspx
    • staceyw5's avatar
      staceyw5
      This is exactly what I did..... but when i go to upload it is says "please select correct configuration file". What I am trying to upload is
      RBS50-V2.2.1.212.img, and that is when i get the error
      • plemans's avatar
        Guru
        One thing to check. the RBS file is for the satellite and the RBR file is for the main router. Make sure you're using the correct firmware for each. I downloaded the .img file and it worked fine so long as I was on the correct device.
