amweiss's avatar
amweiss
Tutor
Jul 15, 2022
Web Connection Ok, but App says Can't Connect and Offline
I have an RBR 850, bought one year ago, and was working fine until last week.  What is strange is that the orbi mobile app says it can't connect and it's offline but the web interfaces say all is good.   Here's the problem, since the orbi mobile app version can't connect it means that my mobile phone is worthless since no app on the phone can connect to the internet.  The phone doesn't work nor any app on my phone (mail, etc.). This condition prevails until the orbi app says it connects again (which is about every half hour or so and connects for about 20 minutes and then says its offline and can't connect.  All the while, our computers connect just fine to the internet.  More info:
V4.6.8.2_2.1.9
mobile phone - latest iphone
I find this situation reallly strange and will find another router if this one can't be fixed.
Any ideas what is going on is appreciated.  Thanks
  • one more piece of info...I thought originally the problem was with my iPhone, but the problem shows up on all the other mobile devices connected to this router
  • What is the size of your home? Sq Ft?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    • amweiss's avatar
      amweiss
      Tutor
      Modem is ARRIS SURFboard SB8200 DOCSIS 3.1 Gigabit Cable Modem
      all satellites are placed as per the link you gave...house is 3500 sq feet.  Again, this only happens with iphones..not any laptops or desktops...just iPhones all running the latest OS.  This doesn't happen on any other wireless system...only with Orbi
      • FURRYe38's avatar
        Guru
        What happens if you turn OFF one RBS and run just the RBR and 1 RBS only?
        I would try running the RBR transmit power at 50% as well.
        Might try setting manual channel 1 and 40 and set CTS from 64 to 500 or try 2347.
