HomeUserguy's avatar
HomeUserguy
1 -2 times per day router goes offline
I have an rbr850 on the latest firmware however 1-2 times per day the system completely goes offline (like a reboot) everything in the house wireless or wired loosed connectivity.  Its random but seems to happen almost everyday in the evening.
the SSID is gone from broadcating and the entire system goes offline.
Its take about 1min and everything comes backonline and the work until the next event.
From what I can find, I dont see any system logs or admin logs on the device.
1. Are there any logs I can look at to see what is happening?
  • I am seeing the same thing happening recently with my same setup. RBR850 and 2 RBS850's.  I have used them for a year with no issues and now it's a daily occurrence that the RBR appears to be rebooting.  Internet router continues to be online and connect, but SSID and connectivity to RBR/RBS drop and comes back in a couple minutes.
    I'm on the latest Firmware for all 3 devices as well. Any suggestions would be appreciated.
    • InLV's avatar
      InLV
      Tutor
      I started having the same issue about the same time. Nothing has changed with the physical set-up or devices connected.
      The router has worked fine since 2019, but now keeps going offline many times a day for less than a minute to about 5 minutes. Did you get a resolution?
      • FURRYe38's avatar
        What NG router model do you have?
  • FURRYe38's avatar
    HomeUserguy MikeS2021
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    • MikeS2021's avatar
      MikeS2021
      Firmware is 4.6.7.13 on all 3.
      Service provider is Spectrum, modem model E31T2V1.
      Home is just over 4k sqft. Satellites are spread way out.
      It’s all been working fine for over a year now.
      • FURRYe38's avatar
        Is there a front LED when this happends on the RBR?
