gamenlegend
Aug 09, 2022Guide
About 2/3 weeks ago began having issues where the Orbi
Can I get access to the beta as well. About 2/3 weeks ago began having issues where the Orbi would lose internet connection from my xfinity modem. I tried restarting the modem and doing a manually upgrade to 4.6.8.5. When the issue happens, some 10-15 times a day, usually I get a DNS issue on the webpage.
When connected directly to my modem (a few other devices) this doesn't occur. It strictly seems to happen to devices attached to the orbi system. Some help would be greatly appreciated.
There is no beta FW currently available.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Is IPv6 enabled on the RBR?
Do you have email logging enabled? https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Enable-Email-Logging-and-Router-Reboots/td-p/2231485/jump-to/first-unread-message
- Provider: Xfinity
model#CGM4331COM
Always in bridge mode.
No issue with internet dropping when connecting devices straight to modem via ethernet. Devices connected to orbi router via ethernet lose internet as well.
Yes
The outlined restart process has been done multiple times.
Yes
3600 Sq ft
What is the distance between the router and satellite(s)?
About 70 ft to downstairs unit. Second satellite has an ethernet backhaul.
No. This is something I always disable.
Enabled it after your initial post.- FURRYe38Guru - Experienced User
What mode is your ISP modem working in? Router or Modem only?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry #2 first...
