Floridaham
Aug 23, 2022Follower
AC1750 to BSR750 upgrade tips
I currently have a AC1750 router supported by 2 range extenders. I have purchased an RBS750 router to replace the Nighthawk. I have assigned multiple devices, their own ip address so when the power...
Aug 23, 2022Guru - Experienced User
I wouldn't use a backup but you could always use the same ssid/password as the original router so devices auto-connected.
