Sevo123
Oct 25, 2019Apprentice
Additional satellites
Hi I want to purchase the new Orbi AX unit but I need help. Where can I purchase more Satellites from? If I possibly purchase 2 units can I use the additional router as a satellite?
No additional satellites available separately currently.
- Chuck_MMentor
I purchased the AX a few days ago and installed this am.
Was pleasantly surprised to see that the RBS50 sattelites I have work just fine on the Orbi AX.
In fact, I have one RBS850 sattelite, one RBS50 satellite and my original RBR50 in AP mode hard wired back to the RBR850.
Smooth as silk.
- DoctorALuminary
I wonder If an old NG non mesh router will work in AP mode. I am horder and kept WNDR4500
Chuck_M wrote:I purchased the AX a few days ago and installed this am.
Smooth as silk.
- Sevo123ApprenticeNot going to purchase the AX unit until they release the satellites to purchase separately .
- BanditoLuminary
You might want to consider the fact that the RBK852 system does provide more useable coverage than the original Orbi system does. Once I got my new system up and running correctly, I have only needed the one RBS850 as a satellite to get the same coverage and speeds that I was getting with three satellites on my RBK53 system. I'm not sure if the power levels are up on the radios or not, but the RBK852 system is certainly giving me equal or better coverage than my original system.
How large on an area do you need to cover? Do you have an Orbi system now and, if so, how many satellites do you have?
'Most places will let you return the system if you're not satisfied, so it may be worth trying out to see if you get adequate coverage or not. How big is your home? Sq Ft? Mines 5000Sq Ft, no issues with WiFi coverage with just the RBR and 1 RBS wirelessly connected. Even with the RBS in the basement and RBR on 2nd story level. Good wifi coverage and operation. Something to try as suggested. If you don't like it, then return it.
- Sevo123ApprenticeNetgear had a live on the orbi AX unit today on YouTube live and Facebook live... I asked about the satellites. They said in the coming weeks it will be available. Finally!!!
Video link https://youtu.be/xPVGv0IHVaoYep
- DoctorALuminary
Thank you for the good news. Now I am going to wait for the the new RBS 850 instead of spending money on RBS 50. People are saying that the usable coverage of RBS 850 is better.
Video link https://youtu.be/xPVGv0IHVao- sjtNJGuide
Does anyone know if/think this will work with the Orbi wifi 6 system to extend it?
https://www.netgear.com/home/products/networking/wifi-range-extenders/EAX80.aspx
- d1mmyApprentice
I would also like to add my request to make satellites available for purchase separately. I purchased the 2-pack, but due to the layout of my home I'm getting very poor signal in my living room. The signal from either my primary router or the satellite has to pass through two exterior walls to reach my living room. Since those exterior walls block a lot more signal than interior walls, I'm a bit stuck at the moment. The signal is usable but it's not great. That's also the room where I watch (streaming) TV. I previously got around this issue by using five Google WiFi pucks and was hoping the Orbi AX6000 system would be powerful to replace the Google system. I could potentially solve the problem with one more Orbi either wireless or using a wired backhaul, but there's no option to purchase it!
d1mmy wrote:I would also like to add my request to make satellites available for purchase separately. I purchased the 2-pack, but due to the layout of my home I'm getting very poor signal in my living room. The signal from either my primary router or the satellite has to pass through two exterior walls to reach my living room. Since those exterior walls block a lot more signal than interior walls, I'm a bit stuck at the moment. The signal is usable but it's not great. That's also the room where I watch (streaming) TV. I previously got around this issue by using five Google WiFi pucks and was hoping the Orbi AX6000 system would be powerful to replace the Google system. I could potentially solve the problem with one more Orbi either wireless or using a wired backhaul, but there's no option to purchase it!
- d1mmyApprentice
My office, where the primary router sits, is only about 20-30' from my living room. The problem is that those 20-30' consist of two exterior walls (surrounding a courtyard in my house). The problem I'm facing is the layout and building materials used in my home. It seems crazy that my signal strength degrades this much in such a short distance, but it is what it is. If I moved my one satellite into the living room, other areas of my house would not have a good signal. That's why I need at least one additional satellite device.
https://analiti.com/shared/5ba22576-8b95-4b3b-8b2f-cd4df5c7cbbb
