PSSnyder
Nov 21, 2020Aspirant
AX-4200 / 6000 MetroNet compatibility
Orbi ax4200 compatibility with MetroNet
I am considering getting an ac4200 Orbi wifi 6 router to use with my MetroNet 500g fiber, but was concerned about MetroNet’s use of CNAT instead of true WiFi 6 addressing. Does anyone have positive or negative experience with MetroNet and Netgear WiFi 6 Orbi routers? Thanks
I am considering getting an ac4200 Orbi wifi 6 router to use with my MetroNet 500g fiber, but was concerned about MetroNet’s use of CNAT instead of true WiFi 6 addressing. Does anyone have positive or negative experience with MetroNet and Netgear WiFi 6 Orbi routers? ThanksMost of the people who participate in this forum own the original Orbi products. Netgear created a separate community forum for the new "AX" product line. (Google searches for "orbi forum" lead here, whereas the AX forum is at:https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax ) If you post in that forum, maybe one of those folks has MetroNet fiber.
There may be a "typo" in the original post. I believe the topic might be IPv6 addressing, not WiFi6 addressing:
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
