jim_dandy_100's avatar
Mar 02, 2021
AX6000 (RBK852 or RBR850) Zoom Drops w/WiFI
Wife's HP Notebook 15t-da000CTO work great with Zoom when using ethernet but drops out a lot when using wifi.   Wifi card in HP is a realtek RTL8822BE PCIe adapter.  Computer was bought in December 2019.  I made sure the realtek had the latest drivers over the weekend.
Prior to the "upgrade" to the Orbi, the wife always zoom'ed wifi (5G network) with the old Asus router - no problems.
She is within 25 feet of the main Orbi router.  She's not in love with connecting the ethernet to Zoom
To me, sure seems like a wifi thing.  Any thoughts on what I should try?  Very happy with the Orbi upgrade except for this issue.
Thank You - Dale
FW version is v3.2.16.22
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try setting CTS to 2347 to see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
    I would try testing with AX mode disabled on the RBR as a quick test to see if anything changes...
    • jim_dandy_100's avatar
      jim_dandy_100
      Hello Sir
      >>What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
      ISP is Spectrum.  Model is Cisco DPC3216
      200M down 10M up
      Router mode
      Guess about 2500 Sq Ft.  with 3 floors.  Router is middle floor front of the house.  Sattelite is 3rd floor back of the house.
      Guess between 30 - 40 feet - maybe a bit more - The house was probably built in the 1920s
      Auto for 2.4GHz but definitely one of the devices is on channel 8
      5GHz is channel 48
      Very few neighbors and the closest is 500 feet away.  Downloaded WiFi Commander and other networks were very far away
      Have not tried this but this will be the first thing I try
      Maybe I'll try this but dang everything works so good except the wife's computer (and she doesn't zoom everyday)
      >> FW
      Did not yet update FW.  It's a bummer to see that sometimes this does more harm than good.  When I go to do this I'll ethernet into the sattelite - do that first.  Then ethernet into the router and do that second.  Any other reccomendations to make this process as foolproof as possible?
      So, with the answers I gave - do you have any reccomendations?
      Thank You - Dale
      • FURRYe38's avatar
        You might set manaul channel 1, 6 or 11 on 2.4ghz.
        You might turn OFF the RBS and see if Zoom still drops...
  • Did you manage to resolve the issue? Im experiencing the same issue with zoom on a HP chromebook.
    I have the RBR850 in AP mode and using the BT homehub. The internet connection is 900MB and i consistently get 200Mbps around the house. I don't experience any issues when on ethernet, so i'm guessing its something to do with the WIFI.
    • FURRYe38's avatar
      Try setting CTS value to 2347 on the RBR. Under Advanced Tab/Advanced Settings/Wireless Settings
