grady7
Oct 26, 2020Aspirant
AX6000 reboot / reconnect slow
Hi,
I've been using my orbi ax6000 for a few months, and mostly love it.
My one issue is that I regularly have to reboot my xfinity router due to local slowdowns. Whenever I reboot the router, it takes almost 30 minutes for the ORBI wifi network to allow device connections. The light on the unit stays purple for the entire process.
Seems incredibly long to be down for a simple router reboot.
Thoughts?
I'd make contact with NG support. Ask about an RMA.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Build in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode- grady7Aspirant
Thanks for your help! Answers below.
- v3.2.16.6
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NAT- Arris Model TG1682G
Couple of options,- I will read through these, and see if I need to reach out to the ISP. I should be able to figure out how to disable the wifi radios.
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode- FURRYe38Guru - Experienced User
OK. Option #3 is the easiest...
