kyngor
May 01, 2020Aspirant
AX6000 VLAN tagging
AX6000 VLAN tagging
Can the AX6000 ($700) please get VLAN - SSID tagging?
There are a lot of (a little more) technical users who want to have more advanced firewall, qos, web filtering, seperation, ... which the RBK50 does not provide. Our only option shouldn't be to go to an Enterprise level setup or other brands.
Please give us the option to do VLAN tagging so we can at least do those things with another device in front of the AX6000.
I don't believe Orbi systems support VLAN tagging on the wifi. I would review the user manual to see if anything is listed there. IF no, then it's not supported. Something to check over in the Orbi Pro forum to see if the Pro version of Orbi AC does.
- kyngorAspirant
Thanks for the reply.
That's what I figured.
It was an attempt to hopefully get someone from Netgear to hear he request :)
Reqeuests can be made here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Good Luck.
