kleek1975's avatar
Aug 25, 2020
AX6000 Wired Ethernet Backhaul issues
My setup:  AT&T LIGHTSPEED (950 Mbps up/ 930 down) to Arris BGW210 Router (serves as Gateway and DNS Server) to Netgear Insight GC728XP 28 port managed switch to 1) RBR850 Orbi Router in Access Point Mode, 2&3) Netgear Insight GC108PP 8 port managed switch to RBS850 Orbi Satellites x2.
My issue is that it's all set up and Internet is working with 5G backhaul between Orbi router and satellite units; however, I would have better speeds served by the ethernet backhaul that I have set up that's not working.  I spoke with L2 tech at Netgear and was informed that the ethernet backhaul on the AX6000 system only works with unmanaged switches.  Anyone know better?  Seems odd to me.
Appreciate any insight.
  • FURRYe38's avatar
    Yep. Having manged switches can cause problems along with green ethernet switches.
    If these are managed switches, Try disabling ALL IGMP protocols on these switches. I would apply settings then power cycle the RBR and RBS and see if the RBS will connect via ethernet.
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
    I use non managed switches and my RBS are ethernet connected. I do have one managed switch however it's IGMP protocols are disabled, it works. D-Link DGS-1100. My other switches are D-Link DGS105/108s and HP ProCurve 1400/1800 series.
    • kleek1975's avatar
      kleek1975
      Guide
      Thanks FURRYe38.  Went ahead and disabled the IGMP Snooping protocols on the switches and rebooted the Orbi router and satellites.  Still no ethernet backhaul.  Any other suggestions?
      • FURRYe38's avatar
        Lets make sure the RBS are working with ethernet, can you directly connect the RBS to the back of the RBR with out a switch in the middle?
