MB_Love
Feb 24, 2021Apprentice
Bad Ethernet cord? Advice please!!
Slow Orbi AX- could it be Ethernet cord?
Here is the deal. Have has Orbi (RBK853) since June - ran flawless. ISP had a wide outage last week. Came back fine. Now 2 days in a row our internet has slowed to a crawl (download, upload fine). Reset router and modem- nothing. Then I unplug Ethernet cord to modem and plug PC into modem. Speed is good. Plug Orbi back into modem and then it’s fine. What would cause this ? Resetting does not work, but Unplugging Ethernet to modem and plugging back in does?
Both today and yesterday unplugging Ethernet work- has this happened to anyone else. Advice please!!
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- MB_LoveApprenticeModem is Arris TG862G
I have RBR850 with 2 satellites - latest firmware v3.2.16.22- FURRYe38Guru - Experienced User
Your ISP Modem already has a build in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
