romainvallee's avatar
romainvallee
Blocked devices
Hello,
I installed an Orbi RBK852 a little over a week ago. Last Friday, it started blocking all devices. I had to reset it and reset everything. It worked fine this weekend until today when it started again... Both times when I wasn't home... Has anyone else had this problem?
I can't access the router's web interface remotely (with the external IP address and port 8443. The port is open on my internet box). And the Orbi app doesn't report any problems and lacks control.
  • FURRYe38's avatar
    Have you factory reset the system and setup from scratch using a PC and web browser? Try following this: https://community.netgear.com/kb/en-orbi-knowledge-sharing/orbi-systems-manual-factory-reset-process/2456340
  • Problem solved. It was an application that made it look like an attack and Armor was blocking everything. UPnP wasn't enough, I had to manually do the port forwarding for this application.
    • FURRYe38's avatar
      Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
      Enjoy. 📡
