Nismoairuk's avatar
Apr 28, 2023
BT TV Help with Orbi 963
Hi
Does anyone have the latest experience on using the Orbi directly connected to Fibre and using BT TV?
I've tried enabling the BT IGMP profile in WAN settings but can't get the TV streaming to work.
Updated the firmware from new and factory reset in the hope I may get more ISP profile options to preset upon setup. However, there only seems to be Malaysia and France profiles available from a drop down list and 'Orange IPTV' streaming?
Any help much appreciated!
  • michaelkenward's avatar
    michaelkenward
    What are you using to get BT TV?
    I have one of a BT TV Box Pro running on an R7000P with no need to make any adjustments.
    • Nismoairuk's avatar
      Nismoairuk
      Tutor
      Thanks for your reply, I have been tearing my hair out with this!
      So my Orbi 963 is connected directly to the ONT and then BT Pro Box connected to Orbi wirelessly (wired not an option).
      I've tried the BT IGMP setting but doesn't work.
      Literally just tried my previous Asus AX11000 with multicast enabled and BT TV worked straight away. Slightly annoying and now thinking how/why the Orbi can't stream the BT TV channels
        michaelkenward
        Fibre? ONT? I should be so lucky.
        What firmware is on the Orbi?
        I have used Powerline Ethernet to make the link between router and wired devices like BT's boxes.
