SkylerPeterson's avatar
Mar 29, 2026
[BUG REPORT] RBRE960 Stops Responding to ARP Requests from WiFi Clients
**Device:** Netgear Orbi RBRE960
**Firmware:** V7.2.8.2
**Mode:** Router Mode (no satellites)
**Summary**
The RBRE960 intermittently stops responding to ARP requests from associated WiFi clients. Affected clients retain a valid DHCP lease and remain 802.11 associated, but lose all network connectivity because the router silently stops answering ARP broadcasts. The issue affects multiple device types and operating systems simultaneously and has been reproducible for over a year.
**Affected Devices**
- Windows 11 laptop (Intel AX211 WiFi 6E)
- Android Samsung Galaxy phones
- Linux desktop
- Most severely impacts WiFi 6E devices, but not exclusively
- Wired devices are never affected
**Symptoms**
- Device shows "Secured, No Internet" on WiFi
- Device has a valid 192.168.x.x DHCP address
- Device cannot ping the gateway
- ARP cache on affected device is completely empty for all unicast entries including the gateway
- Disconnecting and reconnecting WiFi immediately resolves the issue
- Multiple devices can be affected simultaneously
**Root Cause Identified via Packet Capture**
I captured traffic using tshark during a failure event. I am not comfortable sharing raw pcap files publicly. Below is sanitized tshark output limited to ARP traffic only, with MAC addresses anonymized.
**Capture 1 — During failure, before any fix applied:**
1 0.000000000 [client-wifi-adapter] → Broadcast ARP Who has 192.168.1.1? Tell 192.168.1.32
[repeats 24 times over 23+ seconds]
[zero ARP replies received from router at any point]
**The Orbi sends zero ARP replies across the entire 23+ second capture.**
**Capture 2 — During static ARP entry injection:**
[repeats 3 times then stops after static entry injected]
Immediately after the static ARP entry was injected for the gateway, ARP broadcasts ceased and full bidirectional traffic (DNS, TCP, TLS) resumed within milliseconds — confirming ARP resolution was the sole point of failure.
**ARP Table During Failure**
The following shows the ARP table on the affected device during the failure. Note the complete absence of any unicast entry for the gateway:
Interface: 192.168.1.32
Internet Address Physical Address Type
224.0.0.22 01-00-5e-00-00-16 static
224.0.0.251 01-00-5e-00-00-fb static
239.255.255.250 01-00-5e-7f-ff-fa static
255.255.255.255 ff-ff-ff-ff-ff-ff static
After static ARP entry injected and connectivity restored:
192.168.1.1 [router-mac] static
**Network Configuration**
- DHCP pool: 192.168.1.2 - 192.168.1.254
- Active devices: ~8 (well within pool)
- IPv6: Disabled
- UPnP: Enabled
- No satellites
**What This Is Not**
- Not DHCP exhaustion (253 address pool, 8 active devices)
- Not IPv6 conflict (disabled)
- Not a client driver issue (affects Windows, Android, and Linux simultaneously)
- Not a signal or band issue (clients remain 802.11 associated throughout the failure)
- Not ISP related (wired devices are never affected)
- Not a single device issue (multiple devices affected simultaneously)
**Workaround**
Manually injecting a static ARP entry for the gateway on each affected device restores connectivity without requiring a reconnect:
netsh interface ipv4 add neighbors "Wi-Fi" 192.168.1.1 [router-mac]
This is not a viable long term solution, particularly for Android devices without root access.
**Request**
This is a fundamental Layer 2 failure — a router that does not respond to ARP requests from its own associated WiFi clients is non-functional for those clients. Please escalate to the firmware team.
  • FURRYe38's avatar
    Brand and model # of the ethernet and wifi adapters that are connecting to the system?
    Same thing happens with newer FW?
    New - Orbi RBK750/850/860/960 Series Firmware Version 7.2.8.5 Released | NETGEAR Communities
    Just becuase it's not seen on the RBRs web page, doesn't mean you have the latest. NG sometimes only pushes to small batches of systems or if your system isn't registered in there update database, then your system may not see anything they post or push. I recommend always looking at NGs support download web page or check here in the forums for FW updates.
    I've had my 963 series online this past year. No issues seen with v7.2.8.5 loaded on it.
    - DHCP pool: 192.168.0.100 - 192.168.0.200
    - Active devices: ~50 (well within pool) a few outside of the pool using static IP configurations.
    - IPv6: Disabled
    - UPnP: Enabled
    - 2 satellites ethernet connected
  • There is no update on the Netgear Firmware update page, see below. I will manually pull it, update and see if it persists. There are a number of devices impacted, laptops and cell phones are the most prevalent. One of the WiFi adapters is an Intel Wi-Fi 6E AX211 160MHz. Laptop is running Windows 11.
    Status:
     Model NameDevice NameCurrent Firmware VersionStatus
    RouterRBRE960---V7.2.8.2No New Firmware Available
    • SkylerPeterson's avatar
      SkylerPeterson
      Tutor
      I have completed the update to firmware version V7.2.8.5_5.1.21. I have also done a full restart of my modem and router. I will post again if/when the issue persists.
  • I am now update to firmware version V7.2.8.5_5.1.21. I will do a full power cycle of my modem and router and report back if issue continues.
  • Update: The issue has reproduced on firmware V7.2.8.5. Two devices failed this morning while other devices on the network retained full connectivity.
    Affected devices and WiFi adapters:
    • Windows 11 laptop — Intel Wi-Fi 6E AX211 160MHz
    • Linux desktop (Kubuntu) — onboard WiFi adapter on 5GHz
    On the Linux desktop during failure, ip neigh show confirmed:
    192.168.1.1 dev wlp7s0 INCOMPLETE
    INCOMPLETE means the kernel sent ARP requests and received zero replies from the router. Additionally, tshark capture on the Linux desktop confirmed continuous outbound ARP broadcasts for 192.168.1.1 with zero replies from the router — identical behavior to the previous capture on 7.2.8.2.
    Key observations:
    • Two different devices, two different operating systems, two different WiFi adapters failing simultaneously
    • Both devices had strong signal
    • Both devices retained valid DHCP leases throughout the failure
    • Both devices remained 802.11 associated throughout the failure
    • The Orbi sent zero ARP replies to either device
    • FURRYe38's avatar
      What driver version are you using on the Intel AX210 adapter?
      What Windows 11 service pack are you using? 24H2 or 25H2?
      What preferred band is set for the adapters? Auto or something specific. I usually set preferrred back to specific. My AX210 is set for 6Ghz.
      Also is Power Management and Energy Efficiency enabled on the adapter?
      What channels are you using on the RBR?
      If other devices are maintaining connection while these two particular ones don't, poossible issue at these two PCs or these adapters.
      Also a factory reset and setup from scratch will be needed to check this.
      Something to contact NG support about as well. If there is something in the FW that needs fixing, they'll need to do it.
