czl6lx's avatar
czl6lx
Can’t connect GE washer and dryer to new Orbi RBRE960
Had GE washer and dryer hooked up to previous Nighthawk router without any issues, switched to a new Orbi RBRE960 and now they will not connect.  I also have the same issue with a Lennox iComfort thermostat.  All of my other IOT devices hooked up automatically to the new IOT network name that the Orbi created.
Any help would be much appreciated.
  • FURRYe38's avatar
    Did you use same SSID name and password used from other router on the RBR router? You can.
    What is the wifi security mode setting? WPA2 or Mixed WPA2/WPA3?
    • czl6lx's avatar
      czl6lx
      Thank you for reply.
      The router automatically created a new SSID, it appended the original with a -IOT, password is the same.  All my other IOT devices connected flawlessly, but not the washer/dryer or my Lennox thermostat.  My security setting for the -IOT is WPA2-PSK (AES), the only other option for this SSID is WPA-PSK (TKIP) + WPA2-PSK (AES).
      • Try setting your CTS/RTS Threshold to 2347 to maximize compatibility with older wireless devices:
        1. Go to the web admin portal at http://orbilogin.com/
        2. Click to the Advanced tab, Advanced left menu, Wireless Settings
        3. Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
        4. Press Apply
        See if that helps.  If problems still persist, next try disabling AX mode for the 2.4Ghz band:
        1. Go to http://orbilogin.com/
        2. Click to the Advanced tab, Setup left menu, Wireless Setup
        3. Uncheck "Enable 2.4G" under the top Enable AX section
        4. Press Apply
