sltoffler's avatar
sltoffler
Cannot pause or block internet for network connected devices
I am using the Orbi RBR850.
Firmware: V3.2.15.25_1.3.15
I cannot pause or block any network connected devices either from the app on my iPhone or through my browser connecting directly to the new router.
I can toggle the pause switch on the app, but nothing seems to happen.
I have my router in "router mode."
I have a case pending with Netgear support---they were supposed to call me back and no one has.
Kind of frustrating as I don't know what else to try.  For the money I paid, I sure would like to be able to block certain devices at will.
Any help would be appreciated!
  • It worked!!!  Thank you so much!!!
    By simply applying that FW upgrade, it now supports the pausing/blocking of internet to connected devices on the network.
    The only other question I have...I was able to upgrade firmware on the router but not the satellite.  Is that normal or should I try something else to upgrade that one?
