LA2
Mar 04, 2023Aspirant
Cbr750 can't setup after reset
The cbr750 received a firmware update last week. I had problems and thought it was solved in this discussion. https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/Cbr750-after-firmware-update-no-internet/m-p/2298109#M3905
The Orbi started randomly blocking various devices yesterday. After numerous issues and a factory reset today I am unable to connect to the Orbi with any device. The Orbi app now says that my access is denied when I try to setup the orbi via the app. I have tried on 2 different phones. At this point I think the Orbi is dead or the firmware had malware. Has anyone had issues with the Orbi after this firmware update to v4.6.14.4?
There is a link at the bottom of the page telling you to download the orbi app. Link says if you have a mobile device, select here. This takes you thru the web browser based setup wizard/
Ensure your WiFi adapter drivers are up to date.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- LA2AspirantNeed to add, I was stuck in a loop during setup in the app. When it says to connect via wifi to Orbi and I entered the password, I received a message to sign in to connect to the network. When I clicked on the message a window opened showing to download the app and connect through it. Gee, isn't that what I already did?
Set up the CBR with a wired PC and web browser at 192.168.1.1.
- LA2AspirantI tried that. I get the same browser window telling me to download the Orbi app to connect at the app store or play store.
I have uninstalled and reinstalled the Orbi app multiple times. I can't get past the Netgear login each time even though I have the correct password and user name. I have tried my login even with the Orbi off. It seems like the Orbi is not completely uninstalling all the information.- LA2AspirantI was able to get in. I changed my password and also at the login screen I selected to log in with a one time password which worked.
I am waiting to see if all devices are stable on the network. One new Windows 11 laptop is now dropping the connection off and on even though "reconnect automatically" is selected. It previously connected at WPA3 but had to roll back to WPA2 for some legacy devices.
