stardustdron's avatar
Mar 24, 2021
CBR750 Downstream LED always blink white light
My Orbi CBR750 is getting internet connection from my ISP router via LAN connection and its always blink its downstream LED white light all days. I really want to turn it off but in the settings, there isn't such an option for that.
Can someone please help me?
  • plemans's avatar
    Blinking usually means its scanning for a downstream channel.
    do you have a screen snip of the cable connections page? That shows the link status
      • plemans's avatar
        Photos have to be approved by a moderator. You can click on "choose file" and add them 1 at a time (only allows 1 per post) and they're accessible right away
