cshep5528's avatar
Dec 24, 2022
CBR750 not working with Comcast/XF
Having the same issue in Denver thanks to ISP "upgrades" from comcast.  Just messaged Blanca_O . Keep me posted on progress please.
  • So after 2 hours on the phone with Xfinity they told me that the orbi 750 doesn't work with 1gb internet. I downgraded to 800 mbps. Now I am stuck paying $30 more per month for slower internet.  I hate comcast.
    • Cinemagic310's avatar
      Cinemagic310
      Guide
      thats not true because I have it and it works fine! Download speeds are tyoically 820 to 1134
  • So the 800 mbps failed the same as the 1G did.  Arguing with comcast for a refund as I write this.
    Hopefully Blanca_O can figure this out quickly.
  • Another 5 hours on the phone with xfinity and netgear this week. Router cut out 3 times.  Does anyone know how to formally request a refund?  I am also planning to submit a request with the state AG for false advertising.
    • FURRYe38's avatar
      We need the following from you:
      PM me the MAC address and serial number from the CBR.
      Please enable debug logs on the CBRs web page under 192.168.1.1/debug.htm
      Enable WAN/LAN capture as well.
      Please post the following here in the forum:
      FW version on the CBR.
      Please post a copy and paste of the modems connection status and event log page.
      https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
      https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
      The ISP made changes to there speed tier program with out letting users know. They removed support for 1Gb and split the tier to 800Mpbs and 1.2Gb which seems that in some areas, the ISP is not supporting the CBR on the 1.2Gb tier. So some of this is ON the ISP. The CBR had been working fine up to this point until the ISP made changes. SInce the CBR only has 1000Mpbs LAN ports, doesn't make sense to have the 1.2Gb speed since you'll never see much over 900Mbps on the LAN side thru the CBR750. The CBR works as advertised on the 800Mbps speed tier.
      • FURRYe38's avatar
        Please post a copy and paste of the modems connection status and event log page from the CBR.
        cshep5528
  • FURRYe38's avatar
    There we go...
    I see a few channels that are a bit over the power range recommended by NG:
    https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
    I'd ask the ISP to reduce the power on the line a bit. Ask about a inline attenuator to help here. Up link is 5dbm so if they can get the down link around same, would be good.
    Have some Correctables but not horrible. Be sure to check all coax cable fittings and ensure they are screwed in to the jack in back well and snug. Be sure coax line is of good quality RG6 cable. Check for any coax line splitters as well.
    Also what FW version is loaded on the RBS and CBR?
    There is newer FW for both if you haven't already loaded them:
    https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/New-CBK750-Firmware-Version-4-6-14-4-Released/td-p/2287231/jump-to/first-unread-message
    Be sure to update the RBS first then CBR lastly.
    Are you still on the 800Mbps speed tier from the ISP?
    • cshep5528's avatar
      cshep5528
      Star
      Thanks FURRYe38 I will call comcast when I get a chance.  One of the steps their tech took was to move the Modem directly to where the coax lines come into the house so we should be good there.  I am still on 800 speed with them, yes.
      As for firmware see below:
      • FURRYe38's avatar
        Where is the CBR located? Hopefully on main level or 2nd level of the home. Basements are not recommended.
