hgs71
Sep 14, 2020Aspirant
CM1000 and RBK753
Question 1: Is the CM1000 a good match for the RBK753 package?
Question 2: With the RBK753 package, is it possible to run one satelite via ethernet and the other via
WiFi?
Thank you.
hgs71 wrote:Question 1: Is the CM1000 a good match for the RBK753 package?---if its supported by your ISP, then sure. If supported by your isp, it should be good up to gigabit speeds.
WiFi?----yes
Thank you.
WiFi?----yes
Thank you.
- hgs71Aspirant
Thank you.
