trmoore2's avatar
trmoore2
Conflicting IP address? (NETGEAR AX4200 Orbi WiFi 6 )
Total layperson when it comes to networking!  My Orbi (NETGEAR AX4200)
V4.6.5.14_2.0.54
crashes every 3-4 weeks.  Even after a reset of the modem (Netgear Model # CM1000V2) and Orbi router, my hardwired devices will not work. (the wifi usually contines to work).  I have to unplug all of my hard wired cables on my "16 port unmanaged  Netgear GS316 switch."   I reconnect them one by one and this usually fixes the problem.
I've been told i have a duplicate IP address conflict?  When I go to the http://orbilogin.net site and check the IP addresses, they seem to be no duplicate IP addresses.  I have approximately 20 hard wired devices (thermostats, Roku's, destop computer, etc).   Any solution for this problem?
Thanks, Tom
  • CrimpOn's avatar
    CrimpOn
    Can you take a screen shot of this error message and attach it so we can see it.
    • trmoore2's avatar
      trmoore2
      There is no “error Message.” A couple of people have mentioned that is the most likely reason. I could be wrong.
      • FURRYe38's avatar
        How many wireled and wireless devices do you have all contected at one time?
        Does this happen if you remove the switch from the mix?
    V4.6.5.14_2.0.54
    crashes every 3-4 weeks.  Even after a reset of the modem (Netgear Model # CM1000V2) and Orbi router, my hardwired devices will not work. (the wifi usually contines to work).  I have to unplug all of my hard wired cables on my "16 port unmanaged  Netgear GS316 switch."   I reconnect them one by one and this usually fixes the problem. MyAARPMedicare
    Thanks, Tom
    The Netgear Orbi is technically a set of two or more wifi routers that can connect to your existing modem or router (provided by your ISP) to help blanket your home or apartment in Wi-Fi. There are also several Orbi models that include three wifi units to increase the coverage area.
