JacobF
Dec 30, 2024Aspirant
Connect landline to Orbi?
Hi there,
I'm using my Orbi RBR350 as the router/modem connected straight to my NBN.
Is there any way I can connect a landline to it as well? It doesn't appear to work connecting straight to one of the ethernet ports - assuming I need some sort of adaptor?
Thanks!
Orbi routers do not support telephone service. You have two options:
- Have NBN install a different unit that supports telephone service.
- Subscripe to a Voice over IP service and connect their unit to the Orbi network.
- JacobFAspirantHi there,
Thanks so much for your response.
Is there an adapter I can purchase that would allow me to plug my normal phone line into the Ethernet port of the Orbi router?- CrimpOnGuru - Experienced User
It would probably be most efficient to talk to NBN technical support about your options for telephone service.
